jimduncan1
Aug 09, 2011Aspirant
Setup Grayed out/Installation Fail
I'm baffled by my new ReadyNAS. Please help. Any advice would be greatly appreciated I have - ReadyNas DUO plugged into the first port on my - Cisco WRT400N Wireless Router - OSX Lion with the ...
TeknoJnky
Aug 09, 2011Hero
yea, I mis-read your first post thinking you were going to use the 2tb external drive inside.
you definately need at least 1 drive in the internal bay, you can use any old unused sata drive (2tb or less), just be sure you don't have any needed data on it since it will get erased when you insert into the nas bay.
Once your up on an internal drive, you can setup/configure the nas and attach your external drive to one of the usb ports.
