Neth's avatar
Neth
Several problems with the NVX
Hi there!
I have a ReadyNAS NVX running on firmware 4.2.27.
Lately, i've started to get some issues. It all started when i decided on a new folder structure for my NAS.
I created a new shared folder and some subfolders and started moving data from the old shared folders to the new ones.
Quite instantly i started getting really slow transfer speeds, like 200 kbit/s over LAN. So moving stuff became almost impossible since it took too long.
I whent through all network settings on my router, computer and the NAS itself. I thought i got it improved somewhat as it worked at around 6 Mbit/s for a while, just to decrease to around 2 Mbit/s after about 1-2 days.
At the same time i started to get these issues i also get problems when streaming from the NAS. Low res video which have previously worked without hassle, now start freezing and is almost unplayable.
During the last days the problems have become even worse. I am unable to access the shared folders and i am also unable to access the web gui for the NAS.
As for the shared folders it started when i could not open some excel documents, then it escalated to not being able to access the shared folder at all. Lastly, i couldnt access any shared folder any more.
A for the web gui, it started with only parts of the webpage being loaded after login. I could se some background colors and some borders, but no menu, text or buttons. The page never stopped loading. Then it became worse, so after login i only got a white/blank page which never stopped loading.
So, wha to do?
When the problems started, but i still had access to the webgui, i ran the 2 possible disk checks you can run after rebooting the NAS. Both found no errors, so the disks seems OK.
I then removed one of the disks, because they contain sensitive info which i can't loose - like documents for my company and pictures of my children growing up etc etc, and reinstalled the NAS OS - but the problem remained.
I then made a factory reset. This seemed to do the trick. I could access the NAS both in explorer and via web gui. However, it had wiped my hdd clean :(
I thought everything was fine with the NAS again, so I intended to ask you guys about best procedure for how to extract my data from the hdd which i removed from the NAS. When i connect that hdd to my Win 7 computer, it does detect the drive but it cant mount it and list any files.
However, as i'm writing this i see that i no longer have access to the web gui. After logging in i only get some background colors and borders again, but the page never stops loading. So, it seems my NAS is not fixed and the problem is starting over again.
Any ideas?
Is my NAS toast?
If so, how do i rescue my data from the hdd which is now outside the NAS. I used to have 2 hdd in the NAS, so i should have a complete mirror of all the files on this drive.
I guess the NAS i UNIX based? So do i need to boot a linux dist to retrieve the files?
Any help is appreciated!
Web UI, background colors & borders....
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Sounds like it could be RAM failure still or other hardware failure.
    Sounds like you need to consider purchasing a 314 and considering purchasing data recovery or a 3rd party data recovery service.
    mdgm-ntgr
    Just checked and the disk test passed. So looks like either bad RAM or some other hardware failure.
    Are you comfortable with Linux shell commands? If so, you could try checking to see if the volume will mount in Lubuntu using some commands I can give you, but use them at your own risk.
ProSupport for Business
