ronlaws
Oct 01, 2016Aspirant
Share node seems to be flapping
I have another headscratcher, i've never seen it do this before but it is now causing some grevience. I'm not sure how best to explain it so i took the liberty of making a video of the odd situa...
- Oct 01, 2016
Sorry to answer my own question on this one.. Im not 100% why, but i deleted the bond interface, rebooted the switch, and it still did it.
I then re-created the bond interface and used XOR (Layer 2) this time around (i was using adaptive load balancing last time) and it has stopped behaving oddly.
ronlaws
Oct 01, 2016Guru - Experienced User
An RN100 series can't keep up with a single gigabit connection, so I wouldn't spend much time on bonding.
Even with a faster NAS, bonding (like jumbo frames) often isn't worth the bother. It only really helps if you have multiple simultaneous clients.
So if this also misbehaves, you might try just turning it off, and see if there is any perceivable performance dropoff.
- ronlawsJan 22, 2017Aspirant
I know this reply is late, but i've since spent some time with the RN104 without a bonded interface, I installed soft ether on it since, and needed one of the itnerfaces to use as the bridged port (With no tcp/ip settings) so that accessing the nas was possible without complicated routing, so it's since been running off a single port without any flapping or odd issues. I've also since done a complete factory reset, so any issues i was having are basically resolved at this point.
