clinford
Jun 03, 2017Aspirant
Shares not showing on Readycloud after 6.7.4 upgrade
After the 6.7.4 upgrade the folder shares aren't showing on Readycloud and on Windows app devices say Offline. Same on two PC's on differnet Networks
clinford
Jun 12, 2017Aspirant
Hi JennC,
On the portal is says online but "no volumes or USB disks". On the Windows App is says offline. This is the same from multple machines.
I have rebooted the NAS and site Router but still the same.
Thanks Chris.
JennC
Jun 16, 2017NETGEAR Employee Retired
Hello clinford,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
