apara
Sep 14, 2012Aspirant
Should I run "Volume Scan" regularly?
I have ReadyNAS NV+ device which has been working just fine with 4 2 terabyte drive in XRAID configuration. I have read that sometimes spots on the drive go bad and unless scrubbing is done those spo...
apara
Sep 15, 2012Aspirant
Thanks Stephen. Is there anything I can do on my ReadyNas NV+ to come close to scrubbing?
You mentioned that if the scan finds issues there may be negative consequences? Will I loose my entire volume, or is it just going to expose files which are bad? Is it recommended that I do a scan if I have not done it for a long time?
Thanks.
Thanks.
