gdeguillebon
Sep 16, 2017Star
Since Google Drive is enable, Disk spin-down does not work anymore
Hello,
Since Google Drive sync is enabled on my readynas (RN314), the spin-down does not work anymore.
After disable the sync, the spin-down is working again
Did you experiment that ?
the problem seems the same with dropbox sync.
Thanks for your help
Below some logs:
google-drive.log
-- Logs begin at Sat 2017-07-29 04:43:16 CEST, end at Sat 2017-09-16 10:19:55 CEST. -- Aug 24 21:33:15 READYNAS ng-csd[13398]: Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Aug 24 21:33:15 READYNAS ng-csd[13398]: W0824 21:33:15.702988 13398 FSCache.cpp:78] Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Aug 24 21:34:11 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = download_20150412_204649.jpeg. Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: E0824 21:34:11.493209 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = download_20150412_204649.jpeg. Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: E0824 21:34:11.495277 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = lille.jpg. Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: E0824 21:34:15.760298 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = lille.jpg. Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: E0824 21:34:15.760414 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = file.jpg. Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790344 13442 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = file.jpg. Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790473 13442 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790591 13442 SyncUpsyncFile.cpp:359] Failed to update file. local file = /data/Drive_gdg/Google Photos/file.jpg, remote file = /Google Photos/file.jpg. INVALID_ARGUMENT: localPath or remotePath shall be file Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to update file. local file = /data/Drive_gdg/Google Photos/file.jpg, remote file = /Google Photos/file.jpg. INVALID_ARGUMENT: localPath or remotePath shall be file Aug 24 21:34:24 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = paris.jpg. Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: E0824 21:34:24.035274 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = paris.jpg. Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: E0824 21:34:24.035425 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.254144 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.256642 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.258381 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.259907 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.264672 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.266196 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.267810 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.269354 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted
... Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.280009 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.281559 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.283053 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.284624 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.286243 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 22:33:12 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 24 22:33:12 READYNAS ng-csd[13398]: E0824 22:33:12.522763 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 24 22:33:13 READYNAS ng-csd[13398]: Request failed, now waiting 776 ms before attempting again. Aug 24 22:33:13 READYNAS ng-csd[13398]: W0824 22:33:13.627715 13398 WSClient.cpp:128] Request failed, now waiting 776 ms before attempting again. Aug 24 23:33:22 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 24 23:33:22 READYNAS ng-csd[13398]: E0824 23:33:22.308737 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 24 23:33:23 READYNAS ng-csd[13398]: Request failed, now waiting 662 ms before attempting again. Aug 24 23:33:23 READYNAS ng-csd[13398]: W0824 23:33:23.406625 13398 WSClient.cpp:128] Request failed, now waiting 662 ms before attempting again. Aug 25 00:33:31 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 00:33:31 READYNAS ng-csd[13398]: E0825 00:33:31.477128 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 00:33:32 READYNAS ng-csd[13398]: Request failed, now waiting 390 ms before attempting again. Aug 25 00:33:32 READYNAS ng-csd[13398]: W0825 00:33:32.772245 13398 WSClient.cpp:128] Request failed, now waiting 390 ms before attempting again. Aug 25 01:33:39 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 01:33:39 READYNAS ng-csd[13398]: E0825 01:33:39.726773 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 01:33:40 READYNAS ng-csd[13398]: Request failed, now waiting 668 ms before attempting again. Aug 25 01:33:40 READYNAS ng-csd[13398]: W0825 01:33:40.841905 13398 WSClient.cpp:128] Request failed, now waiting 668 ms before attempting again. Aug 25 02:33:48 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 02:33:48 READYNAS ng-csd[13398]: E0825 02:33:48.316488 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 02:33:49 READYNAS ng-csd[13398]: Request failed, now waiting 585 ms before attempting again. Aug 25 02:33:49 READYNAS ng-csd[13398]: W0825 02:33:49.414007 13398 WSClient.cpp:128] Request failed, now waiting 585 ms before attempting again. Aug 25 03:33:57 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 03:33:57 READYNAS ng-csd[13398]: E0825 03:33:57.696195 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 03:33:58 READYNAS ng-csd[13398]: Request failed, now waiting 273 ms before attempting again. Aug 25 03:33:58 READYNAS ng-csd[13398]: W0825 03:33:58.788640 13398 WSClient.cpp:128] Request failed, now waiting 273 ms before attempting again. Aug 25 04:34:28 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 04:34:28 READYNAS ng-csd[13398]: E0825 04:34:28.741219 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 04:34:29 READYNAS ng-csd[13398]: Request failed, now waiting 769 ms before attempting again. Aug 25 04:34:29 READYNAS ng-csd[13398]: W0825 04:34:29.858224 13398 WSClient.cpp:128] Request failed, now waiting 769 ms before attempting again.
spinndown.log
Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 1 [sda,0:0:TOSHIBA_DT01ACA100:94Q8JWAFS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 2 [sdb,0:1:TOSHIBA_DT01ACA100:94M7XYBNS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 3 [sdc,0:2:TOSHIBA_DT01ACA100:94M8AU0FS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 4 [sdd,0:3:TOSHIBA_DT01ACA100:3311NN6NS:MS2OA750:7200] Aug 25 03:58:34 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 03:58:52 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:16. Aug 25 04:09:33 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:09:35 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:09:43 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:08. Aug 25 04:09:43 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:05. Aug 25 04:14:03 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:14:06 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:14:28 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:22. Aug 25 04:14:28 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:20. Aug 25 04:14:49 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:14:51 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:14:58 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:07. Aug 25 04:14:58 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:05. Aug 25 04:19:29 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:19:32 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:19:44 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:12. Aug 25 04:19:44 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:10. Aug 25 04:20:04 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:20:07 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:20:19 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:12. Aug 25 04:20:19 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10. Aug 25 04:25:20 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:25:22 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:25:30 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:25:32 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:25:35 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:13. Aug 25 04:25:35 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10. Aug 25 04:26:05 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:33. Aug 25 04:26:05 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:30. Aug 25 04:30:35 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:30:38 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:30:50 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:12. Aug 25 04:30:50 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10.
The reponse from Netgear support team !
I just got a return from our engineers. Unfortunately the spin-down is not meant to be used with a cloud application. This one uses a service that will constantly check for updates. It may be put in the future an option to create a programming, but for now it is not yet planned.
- Marty_MNETGEAR Employee Retired
Hello gdeguillebon,
It does appear that there is somewhat conflict between the Google Drive and Disk spindown on your NAS. I have tried to simulate the concern in our laboratory and I did not encounter the problem, I was able to enable both feature at the same time. What firmware is your NAS running at? Have you tried reflashing or upgrading the firmware?
Marty_M
NETGEAR Community Team- Marty_MNETGEAR Employee Retired
Hello gdeguillebon,
Have you tried reflashing the firmware? You may also want to try the beta firmware 6.8.1 or 6.9.0 and check if it will make any difference. I would recommend to have a back of the data save on the NAS before further troubleshooting.
Marty_M
Hello gdeguillebon,
I believe you have an option to roll back to the latest official firmware version if in case the beta firmware did not address the concern.
Marty_M
Hello Marty,
Thanks to look my problem.
my firmware is ReadyNASOS 6.8.0.
do you need some others logs file
Best
