forquer's avatar
forquer
SLOW backing up to USB
Hello all!
This is my first post here so forgive me if I'm asking something i did not find in the forums already.
We have lots of sites with the NV+ NAS and here is our setup;
ESX4 with Vranger 4 backing it up to a daily share on the NV+
NV+ built in backups backing up the Daily share to USB drives: specifically the Seagate EXTREME 1TB model
Vranger backups are NOT running at the time the NV+ is trying to backup to USB
for some reason it takes forever to backup to the USB drives, were talking 24-72 hours for 200-300gb of data
has anyone else seen this issue? Why would the NV+ be sooo slow backing up to USB 2.0 drives plugged directly into the back USB ports of the NV+??
Thanks in advance!
Clay
  • mjw wrote:
    A new version of ntfs3g is now included in the latest raidiator firmware so there's no need to manually install ntfs3g any more.
    I'm not certain this is correct, at least not for the 4.1.8 version running on the NV+. I can certainly vouch for the fact that USB backup using 4.1.8 on an NV+ to a NTFS USB drive is brutally, painfully, impossibly slow.
    if your performance is slow then there's not much you can do except make sure you use incremental backups.
    Yeah but you gotta get the initial backup made.
    I do wonder if it's possible to change the priority of the backup command within the NV+ to make it work faster. As it seems now, the USB transfers are the lowest of the processes, at least for my NV+.
  • ewok's avatar
    ewok
    NETGEAR Expert
    Make sure you have Fast USB Writes enabled. You may need to reconnect the drive after enabling the option.
    The quickest way to do the initial full backup is to connect your ntfs drive to a pc, connect the pc via gigabit Ethernet to your nas and do the first copy that way.
    Not sure if this will retain file ownership and permissions though, so you might just want to take the hit of doing the initial backup directly from the readynas to be safe. Worst case a 2TB backup should run for less than a week.
ProSupport for Business
