jon_russ5's avatar
jon_russ5
Apprentice
Aug 03, 2017
Slow ReadyNAS RN104
Hi,   I have ready many pages on this forum for addressing the slow speeds I have with my ReadyNAS RN104 on my Mac connected to a 1 Gb/s LAN via Cat 6 cable - there are no solutions openly publishe...
  • jon_russ5's avatar
    jon_russ5
    Aug 07, 2017
    OK, I think I've sorted out the speeds via SMB.
    I noticed that copying files from the ReadyNAS GUI yielded speeds ~50MBps, whereas drag and drop was ~10-15 MBps.
    So a little googling took me to this: https://dpron.com/os-x-10-11-5-slow-smb/
    So essentially, all I did was unsign SMB transfers using:
    printf "[default]\nsigning_required=no\n" | sudo tee /etc/nsmb.conf >/dev/null
    And now I have 50-60 MBps read speeds. and ~40-45 MBs write speeds.
    Happy!
    Jon
ProSupport for Business
