aitonk
Oct 20, 2011Aspirant
Slow Transfer / Torrent Upload
I have a ReadyNas NV+ running on Verizon Fios (25 DL / 25 UL) My router/modem is the Actiontec MI424WR My transfer speed even when connected directly to the router with a cat6 cable seems to be...
Oct 20, 2011Guru - Experienced User
What transfer speeds are you seeing? You have a 100 mbit/second router, so the max would be around 11 MB/s.
aitonk wrote: I have a ReadyNas NV+ running on Verizon Fios (25 DL / 25 UL)
My transfer speed even when connected directly to the router with a cat6 cable seems to be much slower than it should be. I am unsure what test to run or how to run the tests to give my exact speeds but I am almost positive it should be much faster.
Even my bittorrent uploads and downloads are much slower than if I were to dl or upload on my PC and I believe I have all proper ports forwarded. I changed MTU settings to 1492 and enabled jumbo frames and did all the stuff in the optimization thread but nothing seemed to work.
Do I need a new router possibly? Is something being blocked? How do I check if anything is wrong or if my speeds are good or not?
Any help is much appreciated
