aitonk
Oct 20, 2011Aspirant
Slow Transfer / Torrent Upload
I have a ReadyNas NV+ running on Verizon Fios (25 DL / 25 UL) My router/modem is the Actiontec MI424WR My transfer speed even when connected directly to the router with a cat6 cable seems to be...
Oct 21, 2011Guru - Experienced User
The next step is to upgrade your ethernet connections to gigabit, instead of 100 mbit.
aitonk wrote: I never really pass 9MB/s. I usually get like 6-9MB/s. How would I increase this speed?
I also have the MI424WR, and switching to something else would disrupt my cable TV service. So I purchased a gigabit switch, and connected all my ethernet to that. The switch then connects to the router. All the in-house wired connections then go at one gigabit. You should make sure the switch you buy has 802.3x flow control support, and also supports 9k jumbo frames. (I have jumbo frames off at the moment, but you want to keep that option open).
You also need to use cat 5e or cat 6 ethernet cable to all your wired devices, so you should check that as well. Most ethernet cables will have that info printed on the cable.
