jeff36
Jan 03, 2012Aspirant
ssh as admin
Ultra6 with RAIDiator 4.2.19. I've installed "enableSSH" and the port is open. Using putty from Windows7 gets me the login prompt, but using admin/password closes the ssh window immediately. If I use...
mdgm-ntgr
Jan 04, 2012NETGEAR Employee Retired
What add-on did you install exactly? To enable SSH for login as a user at least initially you need to enable root login.
For support access there are different addons and even a debug mode.
