jeff36
Jan 03, 2012Aspirant
ssh as admin
Ultra6 with RAIDiator 4.2.19. I've installed "enableSSH" and the port is open. Using putty from Windows7 gets me the login prompt, but using admin/password closes the ssh window immediately. If I use...
mdgm-ntgr
Jan 11, 2012NETGEAR Employee Retired
They made a special add-on called EnableSSH? Never heard of that one before. The add-on they gave you would've been one for support use only as the only SSH add-on enabling SSH access for users is EnableRootSSH as I mentioned above.
