jeff36
Jan 03, 2012Aspirant
ssh as admin
Ultra6 with RAIDiator 4.2.19. I've installed "enableSSH" and the port is open. Using putty from Windows7 gets me the login prompt, but using admin/password closes the ssh window immediately. If I use...
mdgm-ntgr
Jan 12, 2012NETGEAR Employee Retired
Ah. As indicated on that page and I mentioned above the ToggleSSH add-on is for support access to the ReadyNAS over SSH only. It enables them to remotely login as root (the superuser).
