jeff36
Jan 03, 2012Aspirant
ssh as admin
Ultra6 with RAIDiator 4.2.19. I've installed "enableSSH" and the port is open. Using putty from Windows7 gets me the login prompt, but using admin/password closes the ssh window immediately. If I use...
madchops
Feb 08, 2012Aspirant
@MastaCheata thank you, your code worked perfectly. Exactly what I was looking for.
Oh and by the way. EnableRootSsh is an addon that allows you to ssh into your readynas thats it. ToggleSsh is a fix so that you can turn ssh access off.
If ssh service is enabled installing togglessh will disable the ssh service. If you install toggle ssh again it will turn it back on ;/
usermod -s/bin/bash USERNAME
