Aloise
Dec 27, 2013Aspirant
Storage Help (NAS+Media Streaming+RAID+Automatic Backup)
Hi everyone. I'm currently facing a dilemma trying to choose the best storage solution for me. I have just bought a Netgear R7000 (Nighthawk) 802.11ac router and would like to build my personal hom...
Jan 02, 2014Guru - Experienced User
Since you are particularly concerned about data loss, you should not use RAID-0 to span multiple disks into one volume. (fastfwd basically said that, I am just underscoring that point).
4TB drives are more cost-effective for new installations. Also leaving a slot empty makes expanding the array more cost-effective later on - especially with RAID-6, where you need to upgrade 4 drives with the larger sizes to get any space increase at all. Much better to pop in a new drive in the empty slot...
