InTheShires
Jul 11, 2011Tutor
Strange issue. My Sparc unit thinks it's an x86?
I was trying to get RN Photos working a few days/weeks ago, but in doing so hit a problem. Namely this: Uploaded with ImageShack.us I had some time today, so sat down to look at this again...
mdgm-ntgr
Jul 12, 2011NETGEAR Employee Retired
If something is messed up e.g. with the permissions in the /tmp folder, I believe it's possible all add-ons may refuse to install with that error message. I think the /tmp permissions looked alright above. Also remember that NetGear doesn't test community add-ons so if you run some of those there could be unexpected problems related to your selection of those that you are running. There could be a problem caused by a community add-on not doing something right.
Usually a reboot, a firmware re-install with a paperclip and/or cleaning the /tmp folder (removing files no longer needed in there and ensuring correct permissions are set) would resolve the issue, I think.
