apankrat3
Oct 04, 2011Aspirant
Stuck trying to do a factory reset on NV
Hi, I am trying to reset my NV box by following instructions (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) and I am not seeing the described behavior. Here's what I do: 1. I...
Nov 05, 2011Guru - Experienced User
Maybe try wiping the drives again (WD lifeguard's "quick erase" is sufficient). Power down the NV, install the new drives, and just power it up. There is no need to do the back panel factory reset; with wiped drives the NV has to do that (since the OS partition is also gone).
