mrQQ
Jun 10, 2015Apprentice
suddenly started getting fan speed errors
hi,
I run 6.2.4 on RNDU4000, and suddenly started getting errors in log and email:
how to fix this?
Thu Jun 11 2015 9:24:08
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (709 rpm).
Thu Jun 11 2015 9:22:11
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (711 rpm).
Thu Jun 11 2015 9:19:54
Thu Jun 11 2015 9:16:02
Thu Jun 11 2015 9:14:36
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (710 rpm).
Thu Jun 11 2015 9:08:54
Thu Jun 11 2015 9:07:23
Thu Jun 11 2015 9:06:16
Thu Jun 11 2015 9:04:15
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (708 rpm).
Thu Jun 11 2015 9:03:33
Thu Jun 11 2015 9:02:27
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (707 rpm).
Thu Jun 11 2015 9:00:56
Thu Jun 11 2015 8:58:54
Thu Jun 11 2015 8:58:18
how to fix this?
- NhellieVirtuoso
- mrQQApprenticeit might be, but that thread is closed and I have no idea how to fix it? the temperatures are ok, so why does it complain about the speed? or, on the other hand, why does it let the speed drop too much?
- mrQQApprenticeis there any way to fix it?
- CharlesRGuide
mrQQ wrote: is there any way to fix it?
# echo 1000 > /etc/frontview/min_fan_speed_override
# systemctl stop readynasd
# systemctl disable readynasd
# systemctl enable readynasd
# systemctl start readynasd
I believe (provided to me via support - not tested) this will set the minimum speed to 1000 (change as desired). Delete the file and you'll undo what you did.
I use numerous Pros 2s and they yo-yo under load. Fan goes from low 700s to around 1,300. The temperature gets to roughly 85C before it ramps up. Quickly the temperature jumps down and it takes a while to get back to the 700s. - mrQQApprenticewhere do i put this file?
- NhellieVirtuosoThat needs to be done through SSH/TelNet.
- mrQQApprenticeI understand that, however that's a script file which needs to be executed during each boot my guess, so it matters where I put it?
- StephenBGuru - Experienced UserYou are correct in thinking that the folder matters. The confusion here is that this is not a script, these commands are typed once into ssh.
This part is the key:
It creates a min_fan_speed_override file holding 1000 in /etc/frontview
This restarts the NAS application (and I think it would likely be ok to simply reboot the NAS instead). - mrQQApprenticeok, so it sticks even after a reboot?
- StephenBGuru - Experienced UserYes. If you want to change it, you need to replace (or delete) the min_fan_speed_override file in /etc/frontview.
