mrQQ
Jun 10, 2015Apprentice
suddenly started getting fan speed errors
hi, I run 6.2.4 on RNDU4000, and suddenly started getting errors in log and email: Thu Jun 11 2015 9:24:08 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (709 rpm). Thu ...
ATCIS
Oct 12, 2015Tutor
mrQQ wrote:
I think I figured this one myself.
I hadfancontrol installed from early versions where 6 OS did not support legacy fan control. And it worked really well for me since I hadNAS running in my living room and needed it to be quiet. Now I removedfancontrol package and speed jumped to 1700 which is fine since it's hidden away somewhere.
I think I may be experiencing the same (or similar) issue that you had here, only mine was delayed until I upgrade to OS6 version 6.4. If you have time, would you mind checking out my post found here https://community.netgear.com/t5/Using-your-ReadyNAS/Fan-CPU-in-enclosure-Internal-speed-is-below-threshold-after-FW/td-p/990867 and tell me what you think? If you concur, would you mind elaborating on the proper method of removing the fancontrol package as you did?
Thanks in advance!
petermac
Oct 16, 2015Apprentice
Same issue here, upgraded Pro 6 to FW 6.4 and now the system fan is not spinning unless the system temps gets over 70C. I have tried creating the file and restarting the system and it doesn't do anything that I can tell
