ChunkySocks
Sep 04, 2025Guide
sudo: unable to write to /var/lib/sudo/ts/admin: No space left on device
I've SSHed into my NAS and got this message: sudo: unable to write to /var/lib/sudo/ts/admin: No space left on device This has all seemed to start after doing some tinkering with the Logitech...
Sep 06, 2025Guru - Experienced User
ChunkySocks wrote:OK, that gives:
Data, single: total=1.62GiB, used=1.25GiB
System, DUP: total=32.00MiB, used=16.00KiB
Metadata, DUP: total=128.00MiB, used=20.59MiB
GlobalReserve, single: total=16.00MiB, used=0.00B
Are you able to say if that looks ok? Hopefully it does.
That looks ok.
ChunkySocks
Sep 06, 2025Guide
StephenB wrote:That looks ok.
Thanks.
Thankfully I've also managed to restore a backup I made of the persist.db which contained all the ratings, play counts and other meta data so that's a major relief. Relief that I made the backup in the first place plus at the right time so it contained all the UUIDs.
Remaining steps are to:
- install the more recent release in a location outside of the OS partition
- restore the files that contain the track ratings, play counts etc. there
- make sure it's working
- re-install Syncthing, again, in a location outside of the OS partition
- get that up and running then happy days!
Thanks again both for all your posts and help.
