gjs010
Jan 12, 2015Aspirant
Swapping over HDD's from ReadyNAS 102's
Hi, I have 2 ReadyNAS 102’s. For the purposes of fault diagnosis (I want to rule out a hw issue with one of them), is it possible to remove the 2 hard drives from NAS1 and put them into NAS2, and si...
Danthem
Jan 12, 2015NETGEAR Employee Retired
Hi gjs010,
both the data and the os are stored on the disks - you should be able to move disks between two RN102 without any problems whatsoever.
