gjs010
Jan 12, 2015Aspirant
Swapping over HDD's from ReadyNAS 102's
Hi, I have 2 ReadyNAS 102’s. For the purposes of fault diagnosis (I want to rule out a hw issue with one of them), is it possible to remove the 2 hard drives from NAS1 and put them into NAS2, and si...
gjs010
Ok, that sounds good. Thanks.
If the OS is on the HDD's does this mean that all the configuration i.e. Active Directory config, NAS name and whether its static IP or DHCP will move over too? Is there any config/detail that would stay with the NAS rather than go with the HDD?
