evena's avatar
evena
Synchronizing images between Android Phone,Tablet
Hello,
I want to synchronize images on my Android phone, tablet, and Windows 7 PC. Using the ReadyNAS as
a central repository.
Is there an app that can do this.
I know there is an app for the WD MyBookLive that can do this and I am looking for something similar.
Even
  • Ok, so I first looked at at syncness, but I couldn't verify that it is actually supported,
    and will instead try to make sweet home work.
    The first time I ran the installation I was able to connect to the I.P address, and
    select Volume, whatever that is (some form of group).
    It failed to create a test file.
    However, when I now run the installation again I get
    "Failed to access share. Did you
    enable Windows File Sharing ? Check
    user name and password?"
    There is nothing in the logs that suggest anything
    Has anybody used sweet home with readyNAS ?
    any suggestions ?
    Even
  • (Copy of post in Share access and file permissions)
    Ok,
    Not sure what the problem with sweet home was, I have decided to try syncme instead,
    so far it seems to run ok.
    https://play.google.com/store/apps/details?id=com.bv.wifisync&hl=no
    Even
ProSupport for Business
