razvanp
Aug 29, 2023Aspirant
System: Error communicating with UPS 'UPS1' (Back-UPS NS 1500M2)
Hi, I am getting the message System: Error communicating with UPS 'UPS1' (Back-UPS NS 1500M2) followed by System: Communication with UPS 'UPS1' (Back-UPS NS 1500M2) is OK dozens of times a day. A...
aks-2
Aug 29, 2023Apprentice
Since 6.10.9 is relatively new, have you noticed the on a previous OS, or only since moving to 6.10.9?
- razvanpAug 30, 2023Aspirant
Thank you for following up. Yes, I did see it with 6.10.8. That is why I did upgrade to 6.10.9, but I still did see it happening.
- StephenBAug 30, 2023Guru - Experienced User
This is with an APC UPS? I am using an APC UPS with my RN526x, and am not seeing these errors. The model is different though - the NAS lists it as "Back-UPS XS 1500M".
I've seen something similar with a CyberPower UPS, but just ignored it. The NAS still managed to do a clean shutdown when the battery in the UPS drained. I didn't see any evidence of the NAS "stalling" in my case. Perhaps try disconnecting the cable for a while, and confirm that the "stalling" is linked to the UPS connection.
You could try a different USB port on the NAS. If you have other USB devices connected to it, you might also try disconnecting them, and see if that makes any difference.
Thank you. I will try and document the outcome. I will update the thread.
