ThirtyReset
Feb 11, 2016Tutor
System hang, fan issues with 6.4.x on Pioneer Pro, Ultra 6 Plus
I have a pair of 6-bay legacy ReadyNAS units here (a Pro Pioneer and an Ultra 6 Plus), both of which have been hardware upgraded to match the same spec (E7600, 8GB RAM, 6x3TB Seagate ST3000DM001) and...
mdgm-ntgr
Feb 11, 2016NETGEAR Employee Retired
Which teaming method are you using? Some teaming methods are better than others.
ThirtyReset
Feb 12, 2016Tutor
Using 802.3ad LACP, Lyaer 3+4. This was rock solid for better part of 8 months on 6.2.x. The system instability started with 6.4.2 RC1 and continues in 6.4.2. Haven't tried shutting off bonding yet to see if it makes a difference. I moved to 6.4.2 RC1 when it came out to hopefully resolve the fan issues, so I've been chasing this off and on for a month or 2 now I guess. Just stumbled on to this error in the logs recently when looking for some common thread.
I guess I can disable and see if the problem goes away, it's been pretty reliably occurring at least twice a week. Any other suggestions? I have the logs downloaded if anyone wants to take a look.
My fan problem was solved as I noted by replacing the stock 120mm fan with a Noctua. Not really sure why I had to do this, as the fans were nice and quiet under 6.2.x as well, so something changed there, but the new fan has made it tolerable to be in the same room as the server again at least.
- mdgm-ntgrFeb 12, 2016NETGEAR Employee Retired
You can send your logs in (see the Sending Logs link in my sig).
- ThirtyResetFeb 12, 2016Tutor
Thanks much for the offer, will send off shortly. There's some errors in there from earlier today when I was setting up an external drive for backing up the last of the data that would be faster to reconstitute from one location than the several places that feed it to my NAS today, so you can ignore those of course.
Does your switch support Layer 3+4 for LACP and have you configured it to use that?
