tommyhackett's avatar
tommyhackett
System volume root usage (/dev/md0) at 100%
I have recently began getting the error message in logs “Volume: System volume root's usage is 100%. This condition should not occur under normal conditions. Contact technical support.
Some searching in the forums has lead me to use some basic command line tools to search for the problem.
Looking at disk space:
root@TXHReadyNAS:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev             10M  4.0K   10M   1% /dev
/dev/md0        3.7G  3.7G     0 100% /
tmpfs          1009M  8.0K 1009M   1% /dev/shm
tmpfs          1009M  432K 1009M   1% /run
tmpfs           505M  996K  504M   1% /run/lock
tmpfs          1009M     0 1009M   0% /sys/fs/cgroup
/dev/md127      1.9T  730G  1.2T  40% /data
/dev/md127      1.9T  730G  1.2T  40% /apps
/dev/md127      1.9T  730G  1.2T  40% /home
It appears that the problem is /dev/md0 being at 100% usage.
Searching for large files:
root@TXHReadyNAS:~# cd //
root@TXHReadyNAS://#
root@TXHReadyNAS://# du -hsx * | sort -rh | head -10
du: cannot access 'proc/15544/task/15544/fd/3': No such file or directory
du: cannot access 'proc/15544/task/15544/fdinfo/3': No such file or directory
du: cannot access 'proc/15544/fd/3': No such file or directory
du: cannot access 'proc/15544/fdinfo/3': No such file or directory
948M apps
323M var
196M usr
30M lib
30M frontview
16M chunk-stream0-00821.m4s
16M chunk-stream0-00689.m4s
16M chunk-stream0-00601.m4s
16M chunk-stream0-00466.m4s
15M chunk-stream0-00833.m4s
With apps being the largest directory I searched there too:
root@TXHReadyNAS://# cd apps
root@TXHReadyNAS://apps# du -hsx * | sort -rh | head -10
828M plexmediaserver-annapurna
68K transmissionr6
0 DO_NOT_DELETE
I’m not sure that the second part was anything to be alarmed by, but I don’t have much experience with command line tools so can’t go much further on my own.
Logs are also warning me that my Volume data is degraded. I thought I would approach the root usage problem first but felt this might be worth mentioning.
I’m using
Model: ReadyNAS 202
Firmware: 6.9.5
I have everything backed up onto external storage so am ready to go.
Would really appreciate if anyone could help.
  • StephenB's avatar
    Delete all of these chunk files.  They are remnants of plex real-time transcoding - they really shouldn't be writing them to the root, but that's something to take up with the plex folks.
    Are there more of these?  The four in your post don't account for all of the space use (only ~80 MB of it).
    948M apps
    apps is actually a mount point to the data volume, so it isn't part of the problem here.  The "du" errors are also related to mount points.
    It's best to remount the root volume, and search that - it avoids these issues, and can uncover space usage that is hidden underneath mount points.  It's also much faster.
    So start by entering
    mount --bind / /mnt
    That mounts sysroot as /mnt.
    Then analyze space on /mnt
    When done, you unmount it with
    cd /
    umount /mnt
    The cd matters, the umount will fail if you are in a folder of /mnt.
    • tommyhackett's avatar
      tommyhackett
      Hi, thanks for the response. I did a little more searching just after I made the post and think I'm in a good place now.
      You're right, there were more of the chunk files (1461 written to the root!) and removing them appears to have solved my problem.
      After doing that, I think I'm ok with root looking like:
      root@TXHReadyNAS:/# ls -1
      1
      apps
      bin
      boot
      data
      dev
      etc
      frontview
      home
      init-stream0.m4s
      init-stream1.m4s
      lib
      lost+found
      media
      mnt
      opt
      proc
      root
      run
      sbin
      selinux
      srv
      sys
      tmp
      usr
      var
      root@TXHReadyNAS:/# df -h
      /dev/md0        3.7G  649M  2.9G  19% /
      tmpfs          1009M  468K 1009M   1% /run
      tmpfs           505M 1000K  504M   1% /run/lock
      /dev/md127      1.9T  729G  1.2T  40% /data
      /dev/md127      1.9T  729G  1.2T  40% /home
      /dev/md127      1.9T  729G  1.2T  40% /apps
      I'm really not sure what could have caused Plex to behave this way initially, perhaps I did something wrong when installing/updating it some time. Any way, I have removed and reinstalled Plex using the GUI. No signs yet that it is writing unwanted stuff to the root again, but I will have to keep an eye on it I guess.
      • StephenB's avatar
        You should probably remove these two also, as they were also left there by plex.
        init-stream0.m4s
        init-stream1.m4s
ProSupport for Business
