kokomodrums
Sep 03, 2013Aspirant
System volume 'root' usage is 100%
I've got a client with a Readynas 102, I just started getting this error message in my email today, every ten minutes:
System volume 'root' usage is 100 %. This condition should not occur in normal conditions. Please contact technical support.
I saw another post with the same error and it looks like they did some commands on the shell. I do not have ssh access (but can set it up if need be). Is there anyway I can troubleshoot prior to setting up ssh? They have no add-ons installed, very basic windows file server setup. They have a nightly backup that copies all data to an external drive, maybe it's a log file? On that note, is there a setting to keep logs 'trimmed'?
Thank you in advance!!!!
- kokomodrumsAspirantIn addition, I noticed that they were on 6.0 so I went ahead and updated to the latest version. Still getting the error.
 - mdgm-ntgrNETGEAR Employee RetiredIt could possibly be a log file. The logs are kept trimmed automatically but if a log file grows very fast this might not happen. To look into this SSH access or tech support mode is required.
 - kokomodrumsAspirantWhat command should I do from ssh? I'll get that set up today.
 - mdgm-ntgrNETGEAR Employee RetiredIf you can SSH in you could use the du command.
 - kokomodrumsAspirantThank you for the advice, I will post the results once I've run the command
root@nas-server:~# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 3.9G 0 100% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.9G 0 100% /
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 792K 247M 1% /run
tmpfs 248M 0 248M 0% /sys/fs/cgroup
tmpfs 248M 8.0K 248M 1% /media
/dev/md/data-0 462G 7.5G 436G 2% /data
/dev/md/data-0 462G 7.5G 436G 2% /apps
/dev/md/data-0 462G 7.5G 436G 2% /home
/dev/sdc1 597G 7.0G 590G 2% /media/USB_HDD_2
/dev/md/data-0 462G 7.5G 436G 2% /run/nfs4/home
/dev/sdc1 597G 7.0G 590G 2% /run/nfs4/media/USB_HDD_2
I do very little command line, how do I find out what files/folders are specifically too big? - mdgm-ntgrNETGEAR Employee RetiredThere are multiple ways of doing it but I would tend to do things like:
# du -csh /var
# du -csh /var/* - kokomodrumsAspirantFixed that problem, caused a bigger one. I'll let you see what I did....
root@nas-server:~# du -csh /var
3.6G /var
3.6G total
root@nas-server:~# du -csh /var/*
4.0K /var/agentx
46M /var/backups
34M /var/cache
4.0K /var/cores
4.0K /var/ftp
38M /var/lib
4.0K /var/local
0 /var/lock
3.5G /var/log
4.0K /var/mail
12K /var/netatalk
4.0K /var/opt
368K /var/readynasd
0 /var/run
16K /var/spool
4.0K /var/tmp
8.0K /var/www
3.6G total
So it appears that the log folder was totally full. So instead of being smart and deleting the logs from Frontview (or w/e the web interface is called in OS 6), I decided to try and be smart and delete all the logs from the shell...
root@nas-server:~# rm -rf /var/log/*
4.0K /var/agentx
46M /var/backups
11M /var/cache
4.0K /var/cores
4.0K /var/ftp
38M /var/lib
4.0K /var/local
0 /var/lock
12K /var/log
4.0K /var/mail
12K /var/netatalk
4.0K /var/opt
368K /var/readynasd
0 /var/run
16K /var/spool
4.0K /var/tmp
8.0K /var/www
93M total
It worked. But, it deleted all the subdirectories in the /var/log folder, which are required by ReadyNAS to write logs period. I went and tried turning on email alerts again and kept getting an error that the log/*whatever* directory didn't exist...
So, can anyone running 6.1.1 give me a list of all the subdirectories of /var/log in a clean install??? I really don't want to do a factory reset for such a minor error... - kokomodrumsAspirantOk, the actual error message said that "/var/log/frontview/msmtp.log" didn't exist, so I created that directory and file.
root@nas-server:/var/log# mkdir frontview
root@nas-server:/var/log# cd frontview
root@nas-server:/var/log/frontview# touch msmtp.log
That allowed me to send alert messages now. But I'm worried that I've deleted more folders/files that are gonna cause issues down the road. If I have to do a factory reset, I can, I would just like to avoid it if I can find another solution. - mdgm-ntgrNETGEAR Employee Retired
Try
# touch /.os_update
# rn_shutdown -r
The above will get the NAS to do an OS Re-install which will re-install the OS but leave your data intact.
I would have recommended finding the log file(s) that filled the OS partition and overwriting them e.g.
# echo "" > /var/log/mylog.logClarification: Please note that an OS Re-install should only be done after space on the OS partition has been freed up. Doing an OS Re-install whilst the OS partition is very full may lead to further issues.
