kokomodrums
Sep 03, 2013Aspirant
System volume 'root' usage is 100%
I've got a client with a Readynas 102, I just started getting this error message in my email today, every ten minutes: System volume 'root' usage is 100 %. This condition should not occur in normal...
mdgm-ntgr
Sep 16, 2013NETGEAR Employee Retired
kokomodrums wrote: Thanks for the advice, I will try to OS reinstall next. Will I have to create new users after the reinstall or does it keep all settings intact as well?
It keeps all users. Only settings for which bad values could lock you of of a system would be reset. So the admin password and some network settings would be reset.
kokomodrums wrote:
Also, what can I do to prevent the log files from getting too big in the future?
Well without knowing which log file filled up the OS partition it is difficult to say.
