kokomodrums
Sep 03, 2013Aspirant
System volume 'root' usage is 100%
I've got a client with a Readynas 102, I just started getting this error message in my email today, every ten minutes: System volume 'root' usage is 100 %. This condition should not occur in normal...
lobbie1978
Apr 04, 2014Tutor
lobbie1978 wrote: Just received the same error message 15 minutes ago and 5 minutes ago. I deleted the logs from Frontview, but the error message remains... :( I have SSH enabled.
I think I found the problem. For some reason the 'Transmission' add-on installed the download folder in the root directory, filling up the root dir rapidly. Although in the config.json file, the download directory is /Data/Transmission/Incomplete
Weird...
RedBullet
Oct 03, 2015Tutor
So I'm running into this. Right now I am getting emails every 10 minutes saying root is at 100%.
However, df shows everything is fine. Rebooting didn't appear to help...
Is there some hidden space or something??
- StephenBOct 03, 2015Guru - Experienced User
Did you also check inodes? df -i
- RedBulletOct 03, 2015Tutor
Yea, df -i looks fine:
root@Storage:/var# df -i Filesystem Inodes IUsed IFree IUse% Mounted on rootfs 0 0 0 - / tmpfs 504422 524 503898 1% /dev /dev/md0 0 0 0 - / tmpfs 504422 2 504420 1% /dev/shm tmpfs 504422 729 503693 1% /run tmpfs 504422 4 504418 1% /sys/fs/cgroup tmpfs 504422 2 504420 1% /media /dev/md126 0 0 0 - /data /dev/md126 0 0 0 - /home /dev/md126 0 0 0 - /apps tmpfs 504422 7 504415 1% /var/replicate/shm tmpfs 504422 1 504421 1% /home/Andra/snapshot tmpfs 504422 1 504421 1% /data/home/Andra/snapshot tmpfs 504422 1 504421 1% /home/Scott/snapshot tmpfs 504422 1 504421 1% /data/home/Scott/snapshot
So, I did have a couple of things in /var/lib which were taking up space (squeezeboxserver, and mysql). I was able to relocate those to /apps.
But now I am here (which is better):
root@Storage:/# df -h .
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 2.8G 898M 77% /
and I can't figure out what is taking the space...
root@Storage:/# du -sh /var 305M /var
Any other places I should look?
- RedBulletOct 04, 2015Tutor
This morning I am back to nearly 100% used:
root@Storage:/var# du -sh * 0 agentx 61M backups 100M cache 38M cores 0 ftp 46M lib 0 local 4.0K lock 66M log 0 mail 8.0K netatalk 0 opt 960K readynasd 0 replicate 4.0K run 4.0K spool 0 tmp 4.0K www root@Storage:/var# df -h . Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 3.6G 123M 97% /
Where's the space going??? Help!
