JanvdBrink's avatar
Jun 07, 2016
System volume root use is 95%, var/ftp is using it all
Hello,
I have a ReadNas 102 and lately got these error messages that the system volume root use is 95%. After checking the /var folders I noticed that /var/ftp used all the space available. I had FTP enabled for some folders and it looks like the content of those folders is copied into the var/ftp folder.
Maybe a 'stupid' newbe question, but is it normal that this /var/ftp folder is completely used.
Second question: how can I safely remove the content of this /var/ftp folder?
Thanks in advance,
Jan
  • StephenB's avatar
    Usually the shares (e.g., btrfs subvolumes) are mounted on /var/ftp, so if the system is working normally you will see the shares (which are not actually in the /var file system).
    If you enter "mount" do you see the shares on the list?  Something like
    /dev/md127 on /var/ftp/Music type btrfs (rw,noatime,nodiratime,nodatasum,nospace_cache,subvolid=268,subvol=/Music)
    If so, deleting files in there will delete the your data (and won't help your problem).
  • Anonymous's avatar
    Anonymous
    If you want to account what's actually in the OS volume:
    # go to root
    cd /
    # count space usage per folder (only in the same filesystem)
    du -d1 -hx .
    # go to the biggest folder
    cd blablabla
    # repeat the operation
    du -d1 -hx .
    # once you're in the folder that contains the big files
    ls -alh
    • StephenB's avatar
      # go to root
      cd /
      du -d1 -hx .
      cd blablabla
      du -d1 -hx .
      ls -alh
      du -d1 -hx . works in /var/ftp but the rest won't work unless you unmount the btrfs subvolumes correct?  The cd will just take you into the data volume.
      If the space really is in /var/ftp, then it was something written at startup before the data volume.  That has sometimes happened.  Support is of course one option.
        Anonymous
        The -x flag is to account for data only in the current filesystem. The data volume being another one, it's not accounted for.
        http://linux.die.net/man/1/du
        If you really have data into a folder and mounted something on top of it, so I guess you won't be able to account for it this way (because of the cd).
        But I'm presuming, the /var/ftp is not the culprit. It was just taken as is by mistake.
        The user should do proper accounting with -x flag to make sure.
        If you don't want to cd, you can still
        # start with root
        du -d1 -hx /
        # go to biggest folder
        du -d1 -hx /foo
        # and so on
        # to finish with
        ls -alh /foo/bar
    • JanvdBrink's avatar
      JanvdBrink
      Tutor
      Thank you. I actually uninstalled LogAnalyzer and mysql server and removed the specific directories.
      Keep my fingers crossed ....
ProSupport for Business
