NTGR-OPS
Nov 25, 2018Tutor
System volume root's usage is 84%. This condition should not occur under normal conditions.
Hi,
I've seen many instances of this on the web, but no clear instructions on how to fix it. At the moment, I have no apps that are loading (but they should), and my system says no apps are installed (but they are). I hope this is just a function of having a somewhat full root volume.
Any suggestions would be greatly appreciated. I'm somewhat of a newbie, but can follow instructions. I've got SSH enabled and can access the system if needed.
I do not want to do a refresh as I've got way too much data on this system. Al the really important stuff is backed up though.
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.6G 125M 97% /
tmpfs 993M 0 993M 0% /dev/shm
tmpfs 993M 11M 983M 2% /run
tmpfs 497M 1.4M 495M 1% /run/lock
tmpfs 993M 0 993M 0% /sys/fs/cgroup
/dev/md127 22T 14T 8.1T 64% /data
/dev/md127 22T 14T 8.1T 64% /home
/dev/md127 22T 14T 8.1T 64% /apps
tmpfs 4.0K 0 4.0K 0% /data/Pictures/snapshot
- Marc_VNETGEAR Employee Retired
Hi NTGR-OPS
Support can definitely help you out free up OS volume without touching the Data. I wouldn't recommend doing it yourself if you are not comfortable using SSH but others might be able to provide you instructions. If you have full backup of your data you can do a Factory reset, only if you want to.
If you have purchased your RN316 between June 1, 2014 and May 31, 2016 then you are eligible for Lifetime Chat. Just login to my.netgear.com and create a case for Support to assist.
Hope this helps!
Regards
- NTGR-OPSTutor
I'll give that a try. Appreciate the quick response.
- NTGR-OPSTutor
I contacted support right away and still waiting for someone to assist with actually looking at the system. Thyey took my details and all, but details and ETA seems to be slow. I've just asked for an update again. Hopefully 3 days down is long enough.
