grahamu59
Feb 07, 2017Tutor
System volume suddenly full
Strange warnings on my 102 today... The data volume is just over half full (3 TB) on 6.6.1 - seems to be working OK still but this is worrying. Did a balance 2 days ago. No activity taking place a...
bedlam1
Feb 07, 2017Prodigy
AV has a bug and there have been numerous reports such as yours over the past few weeks, a fix is on the way alledgedly.
You should disable AV until then and see what your system reports, you may also wish to enable SSH, whilst you can, just in case your root is full.
- grahamu59Feb 07, 2017Tutor
SSH already enabled (for just in case).
AV now disabled.
df -h is not showing anyting full (max use% is 56%) but rootfs is not listed at all??? Is this the same as /dev/md0 which is 4GB in size 1.3 GB used?
