bshannon
Jul 05, 2017Aspirant
TiVo Bolt backup still not working
A few months ago I complained that backups weren't working for my TiVo Bolt. A few weeks ago a firmware update claimed to fix problems with the TiVo Bolt. And in fact it seemed like it was worki...
JennC
Jul 06, 2017NETGEAR Employee Retired
Hello bshannon,
What firmware version are you using with the NAS? I heard that 6.8.0 will have ReadyDLNA update. Have you tried the BETA version?
JennC
- bshannonJul 06, 2017Aspirant
I installed the 6.8.0 beta and rebooted.
No change in behavior; my TiVo Bolt recordings are still not backed up.
What should I try next?
- JennCJul 07, 2017NETGEAR Employee Retired
Hello bshannon,
That 6.8 is not the official release yet, I may need to check this with others who can probably assist you and get back to you as soon as possible.
Thanks for your cooperation!
- bshannonJul 07, 2017Aspirant
Yes, please let me know what I can do to help you solve this problem.
Thanks.
