alaah
Jan 26, 2018Aspirant
Transfer the hard disk from a device of the same type on a device of the same type
Hello
I have a problem in the storage device of type 104 and I have another device of the same type Is it possible to transfer the Hardsk from this device to the other device without any problem
I have a problem that was presented to the technical support and I have not answered yet
Please reply as soon as possible
You can power down both OS-6 NAS, then move the disk(s). I recommend preserving slot order.
If the target OS-6 NAS uses an x86 processor, the OS partition will be updated. However, some (likely most) apps won't work.
Also, if the target NAS isn't running the same firmware as the source, then the newest firmware will be applied. That is, if the target NAS has newer firmware in its flash, then the disk OS partition is updated. If the source NAS was running newer firmware, then the target NAS flash is updated from the disk.
