haus
May 26, 2017Aspirant
Trouble with CyberPower UPS - one time fault?
I have a ReadyNAS 102 running 6.6.1, connected to a CyberPower CP850PCFLCD UPS. All normal operation until this morning. I have tested this combination *multiple* times, and I can unplug the UPS from...
Sandshark
May 27, 2017Sensei
The NAS won't normally shut down just because it lost communications with the UPS. But the last valid communication it had said it was on battery power, and that appears to be why it shut down. There may have been a short disruption in your power that the UPS did not react to well. Your test seems adaquate to say you don't have a permanent problem and I wouldn't worry about it unless it happens again.
- hausMay 27, 2017Aspirant
Thank you Sandshark. Appreciate the info and I'll keep an eye on it. I was happy to see that it shut down gracefully. I have on and offsite backups of everything just in case.
