tenney
Oct 20, 2014Aspirant
trying to setup rsync job nas to nas with path
I'm trying to setup a pull backup job from NASPRO to NASNV+. I want to backup "sharename/folder/innerfolder" to "newnasshare/innerfolder". I've set the soource host to the IP (same subnet) of NASPR...
mdgm-ntgr
Oct 20, 2014NETGEAR Employee Retired
So the backup job is running on the NV+. Did you enable Rsync for the source share on the Pro?
Try running the backup job anyway even though the test connection gave an error. That path looks correct.
Or better yet create a test share on each NAS and experiment backing up between those. Then when you are comfortable with that create backup jobs for your important files.
