tenney
Oct 20, 2014Aspirant
trying to setup rsync job nas to nas with path
I'm trying to setup a pull backup job from NASPRO to NASNV+. I want to backup "sharename/folder/innerfolder" to "newnasshare/innerfolder". I've set the soource host to the IP (same subnet) of NASPR...
mdgm-ntgr
Oct 21, 2014NETGEAR Employee Retired
Can you run a test.
Create a share on each NAS, configure it the same as the shares you are having problems with and run a test backup job.
If it doesn't work try with a path that is just the sharename.
