tenney
Oct 20, 2014Aspirant
trying to setup rsync job nas to nas with path
I'm trying to setup a pull backup job from NASPRO to NASNV+. I want to backup "sharename/folder/innerfolder" to "newnasshare/innerfolder". I've set the soource host to the IP (same subnet) of NASPR...
tenney
Oct 26, 2014Aspirant
Everything I tried didn't work.
I even tried setting up the rsync backup (pull) to pull the entire share over. It copied maybe 8 or 12 folders by no files.
I tried making sure that the attributes / privs were set correctly and still no joy.
I then tried to push the one folder (<sharename>/outerfolder/desiredfolder) from the remote that I couldn't grab from (the naspro) to the newer nas (just an nv+) and this worked fine. The push of just that one inner folder over is still running and files are being copied.
Bottom line for me: rsync backup job PULL (source is nas pro, destination nv+) would not work no matter what I tried. Changing to PUSH (running on the nas pro TO the nv+ rsync backup job) seems to be running fine. I expect a dozen hours, but it's a runnin'
sheesh. at least it's copying...
