claykin
Sep 10, 2011Aspirant
Ultra 2 Plus 4.2.19 does not fix USB3 problems
I have 3 - 1TB Seagate 2.5" Freeagent Goflex drives (USB3). If I connect any of them to the Ultra 2 Plus front USB port and reboot the NAS, the NAS will not restart. It powers up and blinks the acti...
claykin
Sep 14, 2011Aspirant
ahpsi wrote: FWIW the Seagate "FreeAgent GoFlex - hard drive - 1 TB - SuperSpeed USB 3.0" (mfr part # STAA1000101) does not exhibit this issue when plugged into the front USB port of a ReadyNAS Pro 2 under 4.2.17, 4.2.18 and 4.2.19. T: Bus=06 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 3 Spd=5000 MxCh= 0
D: Ver= 3.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1
P: Vendor=0bc2 ProdID=50a1 Rev= 1.00
S: Manufacturer=Seagate
S: Product=FA GoFlex Desk
S: SerialNumber=NX0JXACX
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
Your unit identifies itself as a "Goflex desk". In my USB_devices.log mine is identified as "Freeagent Goflex". Also if I'm reading the log file correctly, yours is drawing 0mA from the USB port. My bus powered units draw 100mA. Are you sure you have the 2.5" 1TB portable Goflex? To me it looks more like you have a self powered 3.5" unit.
