claykin
Sep 10, 2011Aspirant
Ultra 2 Plus 4.2.19 does not fix USB3 problems
I have 3 - 1TB Seagate 2.5" Freeagent Goflex drives (USB3). If I connect any of them to the Ultra 2 Plus front USB port and reboot the NAS, the NAS will not restart. It powers up and blinks the acti...
claykin
Sep 14, 2011Aspirant
chirpa wrote: Thanks, that is the current version, so that is fine.
claykin wrote: 09/08/2010 ReadyNAS-ProUltra2 V1.4
How about the firmware for the USB3 controller? Are you using the NEC controller in the 2 bay Readynas?
Another thing I notice. When the Goflex is connected to the front USB3 and I powerup the NAS the LED's on the Goflex illuminate and stay lit.
When the Goflex is connected to a rear USB port, the LED's illuminate on powerup for a few seconds then cycle off then on again when the 2 internal disk lights illuminate.
maybe this will help you get a better handle on where this is getting hung up?
