claykin's avatar
claykin
Ultra 2 Plus 4.2.19 does not fix USB3 problems
I have 3 - 1TB Seagate 2.5" Freeagent Goflex drives (USB3). If I connect any of them to the Ultra 2 Plus front USB port and reboot the NAS, the NAS will not restart. It powers up and blinks the activity light once, but then stops. The two disk LED's on the NAS never turn on.
I had the same reboot issue with 4.2.17.
If I move the Goflex to one of the rear USB2 ports the NAS will start OK.
If I wait until after the NAS boots then connect the Goflex to the front USB3 port, it works OK.
Any ideas other than to use a different USB3 disk? I have disabled spindown using the Seagate utility. The reason why I like this model is because I have access to the SATA connectors if I ever need to do recovery, run Spinrite, etc... These drives should work. They work great on my desktop and laptop which both have the NEC USB3 controller.
ProSupport for Business
