samuk
May 21, 2012Aspirant
Ultra 4 - very slow file copy
RAID 5 with 3 2TB Seagate disk. When i copy a 6GB mkv file it copies at 15MB/second over a 1GB link! If i enable Jumbo frames this jumps to 80MB/seconds - but my internet stops working from the ...
May 22, 2012Guru - Experienced User
I suspect logmein works because it is using a 1500 byte MTU, even if jumbo frames are on.
sleepy06405 wrote: Your symptoms are very odd. You lose the ability to browse the internet but logme in still works? Logmein is basically doing the same thing as a www browser does. Do you have any vpn clients installed or anything that would have added additional phantom network adapters to windows?
I think trying the direct connect is the most useful next step - jumbo frames is not the main goal, raising the performance on the slow PC->NAS writes is.
Also, it would still be useful to know the switch model, and what the NAS network stats actually are. The best thing is to copy/paste the statistics before a write test, and then do it again afterwards.
