samuk
May 21, 2012Aspirant
Ultra 4 - very slow file copy
RAID 5 with 3 2TB Seagate disk. When i copy a 6GB mkv file it copies at 15MB/second over a 1GB link! If i enable Jumbo frames this jumps to 80MB/seconds - but my internet stops working from the ...
May 22, 2012Guru - Experienced User
It is not modifying the MTU, I didn't mean to suggest that. Like all applications it does have control over the message sizes it chooses to send. Logmein also uses UDP, so TCP negotiation is not a factor.
sleepy06405 wrote: I have trouble accepting the idea that logmein can modify the mtu. MTU is down at layer 3/4 and logmein is up at layer 6/7 of the osi model. Apps don't jump layers. But I'll butt out, I'm new here :)
What is odd about the problem is that normal web surfing seems to be totally failing, not that logmein continues to work.
