Yoda1492
Dec 02, 2016Luminary
Ultra 6 OS Upgrade from 4.2.30 to OS 6
Hello, I have an ReadyNAS Ultra 6 (RNDU6000-100NAS) running RAIDiator 4.2.30. It has 6 Seagate 3TB drives in it. Since the system is out of warranty, I would like to replace OS 4.2.30 with OS 6...
- Dec 02, 2016
Basic instructions are
- BACKUP, BACKUP, BACKUP
- Download PREPR4TOR6_0.1-x86.bin
- Upload it using the ReadyNAS web gui firmware update, but do not reboot afterwards (avoids the need to do manual factory resets)
- Download R4toR6_6.9.3.bin
- After you upload the addon/firmware and reboot, it will update the firmware and start a factory default.
For links to files see OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT
As you can see it does a factory default, so all data on the NAS will be lost.
At the moment you can still purchase Netgear support (including per-incident support) even though you are out of warranty. If you are running OS 6, that will no longer be an option for you. Though you still could purchase Netgear's data recovery service if needed.
I haven't seen any posting about apps working differently on legacy NAS. The Ultra has less memory than the current shipping x86, which could create issues I guess. The main issue I've noticed here is that sometimes new firmware doesn't handle fans and temperature sensors correctly. So far Netgear has resolved that during beta.
Disclaimer: My pro-6 is running OS 4.2, so I haven't done this upgrade myself - although I do have several OS 6 ReadyNAS.
Dec 02, 2016Guru - Experienced User
Yoda1492 wrote:
All - As to what version of BIOS is on the Ultra 6, according to the BIOS_ver file, my BIOS info is:
05/26/2010 FLAME6-2 V1.1
The newest one is I know of is 6/10/10 - the download link is here: http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
Yoda1492 wrote:
Bedlam1 - The only app that I have on this NAS is PLEX Media Server.
After the upgrade, you'll download plex for OS-6 x86 directly from https://www.plex.tv/downloads/ You'll then install the deb filel by going to the apps page of the web ui, and then use the "upload" control on the top right side of the page. It installs in the background, and it will take a couple of minutes - long enough that you might feel like it didn't work. So be patient on that step. There will be a notification, and there will be a log message when the install actually completes.
mdgm-ntgr
Dec 03, 2016NETGEAR Employee Retired
The BIOS update fixes WOL if I recall correctly.
Plex hasn't released add-ons for RAIDiator 4.2.x for a while now.
Once you're running OS6 you'll be able to run the latest version of the Plex Media Server app.
