Hibtek
Jul 26, 2011Aspirant
Ultra 6 Plus Teaming Question
Hi All, my first post, but here goes I have two Ultra 6 Plus devices, one we have had for about 1 month, with 4 2 TB disks, this is setup with Teaming / Failover (Adaptave Load Balancing), Im sure ...
Hibtek
Jul 27, 2011Aspirant
Thanks Yoh-dah, it was just more annoying that we based the second purchase on the performance / options of the first, its not essential or anything.
If we firmware upgrade do you know if the option will disappear? if it does will the settings be wiped. I guess the safest way is to turn off the teaming and then do the firmware upgrade, and see whats left :-)
I might leave it for a while, both boxes perform the same, sort of 70 - 90 MB /sec
