Hibtek
Jul 26, 2011Aspirant
Ultra 6 Plus Teaming Question
Hi All, my first post, but here goes I have two Ultra 6 Plus devices, one we have had for about 1 month, with 4 2 TB disks, this is setup with Teaming / Failover (Adaptave Load Balancing), Im sure ...
Hibtek
Jul 27, 2011Aspirant
No Apologies needed, I don't think anyone fully understands the Naming convention that Netgear use!
After a bit more reading I have also found that they do not.... or should not be able to join a domain.... both mine have the ability or option to join a domain and one is joined and working well.... it will be annoying if this is taken away, can anyone from Netgear state if this is an issue or not?
Options that we should not have but do and they work ok, it seems to me that lots of people are asking the questions and want this kind of functionality then can we keep it in?
Yoh-dah said in a previous post
"If you have one that shows up supporting it, then the hardware was set incorrectly at the factory."
Does that mean a firmware update can not remove these options?
