dthoms's avatar
dthoms
Ultra 6 stuck "Scan in progress"
The Readynas versions are as follows...
firmware: RAIDiator 4.2.22
ReadyDLNA v1.0.25
The scan is stuck. Unable to identify where the scan has stopped. Read most of the comments on this topic, but none of the question related to my version of the firmware. My firmware versions are newer. Since this is my main repository, it is important to restore access via DLNA. Like most, I've expended considerable money to ensuring the devices in my home work with the Readynas. Now all of my systems are down due to this problem.
Thank you in advance for your assistance.
  • Just a quick question, how do you roll back to .21 ? download the image and install as if an upgrade, or do you have to do anything special? Thanks :)
  • I just want to chime in and say I had the same issue.
    Thanks for posting a solution, I rolled back and it worked. Waiting for a new fixed firmware release now.
  • I have seen a similar thread to this. I can also confirm its a problem with 4.2.22. This needs to be addressed in the next update please.
  • Same problem here!
    ReadyNAS Pro Business Edition (x86 Radiator 4.2.22) ReadyDLNA 1.0.25
  • Really???? This is the level of support one can expect from Netgear???? Months later and no fix. Netgear just moved way down my list of brands to consider when buying tech for work. This should have been patched a long time ago.
  • Hy,
    I create a ticket in the support page for this probleme. i expect for a quickly answer :P
  • Hy,
    The support don't know this problem and see with his high level for that... :(
ProSupport for Business
