kekegsm
Jan 08, 2017Guide
Ultra6 LCD screen problem after 6.6.1 upgrade
Hi Yesterday I upgraded OS from 4.2.30 to 6.6.1. More-less fine (usually fan problem and CPUtemp is constant), but one can't find: LCD screen error. It working 99%, but uncorrect at DISK3. It sho...
- Jan 13, 2017
I had the same problem on an Ultra 6 upgrading from 4.2.30 to 6.6.0 a couple of weeks ago. After I rebooted the disk array rendered properly and I haven't seen that visual problem since (lots of other things don't work reliably—I'm still not sure I shouldn't roll back to 4.2.28 or 4.2.30—but the front-panel display has been fine).
JennC
Jan 09, 2017NETGEAR Employee Retired
Hello kekegsm,
Welcome to the community!
I am not sure if you should update tot he latest instead of going through 6.5.0 or 6.6.0 first since you are using a ReadyNAS OS4 unit. I suggest you back up the data first if you have already have them stored to the ReayNAS volume then factory reset or perhaps wait for other community members who have uploaded OS6 to their OS4 units too to respond.
- mdgm-ntgrJan 09, 2017NETGEAR Employee Retired
Upgrading from RAIDiator-x86 to OS6 requires a factory reset so that will have already been done.
- kekegsmJan 14, 2017Guide
thx Jen, but I am sure, i can. Not the first NAS in my life, dont worry.
adamwilt, after 4-5 reboot, it started to working. Weird.
You wrote "(lots of other things don't work reliably". Please write them, maybe we can found something together.
- adamwiltJan 15, 2017Aspirant
I've listed my various tales of woe at https://community.netgear.com/t5/Using-your-ReadyNAS/OS-6-6-on-Ultra-6-Not-ready-for-prime-time-Do-I-need-more-memory/m-p/1209505#M123199
