danesol
Feb 15, 2022Aspirant
Unable to connect using a browser
All of a sudden when I try and access either the admin page or my own share, i get this message using EDGE or Google Chrome; This site can’t provide a secure connection 192.168.0.10 uses an unsu...
Marc_V
Feb 15, 2022NETGEAR Employee Retired
Welcome to the Community!
That is due to your updated MS Edge and Google Chrome browsers where TLS 1.0/1.1 is not supported or disabled. Legacy NAS running OS4 or OS5 uses TLS1.0.
You need to try using IE or download and install an older version of Firefox as a workaround. You will also need to change a setting where it will not auto update.
Make sure you have access to your data and make backup for security,
HTH
- BMcDoOct 08, 2022Aspirant"You need to try using IE or download and install an older version of Firefox as a workaround. You will also need to change a setting where it will not auto update.". NOT doing that. Netgear crap device is going out with the garbage, where it belongs!
Disappointed (former) customer!
