danesol
Feb 15, 2022Aspirant
Unable to connect using a browser
All of a sudden when I try and access either the admin page or my own share, i get this message using EDGE or Google Chrome; This site can’t provide a secure connection 192.168.0.10 uses an unsu...
Marc_V
Feb 15, 2022NETGEAR Employee Retired
Welcome to the Community!
That is due to your updated MS Edge and Google Chrome browsers where TLS 1.0/1.1 is not supported or disabled. Legacy NAS running OS4 or OS5 uses TLS1.0.
You need to try using IE or download and install an older version of Firefox as a workaround. You will also need to change a setting where it will not auto update.
Make sure you have access to your data and make backup for security,
HTH
BMcDo
Oct 08, 2022Aspirant
"You need to try using IE or download and install an older version of Firefox as a workaround. You will also need to change a setting where it will not auto update.". NOT doing that. Netgear crap device is going out with the garbage, where it belongs!
Disappointed (former) customer!
